Post by captaincaveman on Jun 1, 2012 20:52:21 GMT 1
Seen Norb sells some nice clock faces. As anyone changed any? Just had a quick look but cant see how you would pull the glass off without bending the plastic strip that holds it in place.
Post by crash on Jun 1, 2012 20:58:27 GMT 1
its a soft metal ring mate,you need to slowly remove it from behind bit at a time with a screw driver,bit like taking a tyre off.
Post by captaincaveman on Jun 1, 2012 21:23:09 GMT 1
I take it then the needle just pulls off? Does anyone know if the faces norbo sells are stickers or stick on plates sort of thing?
Post by scoobytoo on Jun 1, 2012 21:38:20 GMT 1
The needle pulls off, make sure you pull from centre part tho OR it will snap! The decals are stickers. I had to sand the face down to just the original plastic so they illuminate correctly. I've got a picture when I did mine so I'll get off this iPhone and grab pc and upload a picky for you
Post by captaincaveman on Jun 1, 2012 21:44:30 GMT 1
Be great thanks
Post by scoobytoo on Jun 1, 2012 22:04:57 GMT 1
Post by captaincaveman on Jun 1, 2012 22:07:47 GMT 1
Its just the 2 small screws then that hold the face on? How did you manage to cut the hole for the needle stop.
Post by scoobytoo on Jun 1, 2012 22:11:10 GMT 1
you have to pull it out with a small pair of pliars, and yes 2 screws
Post by captaincaveman on Jun 1, 2012 22:24:49 GMT 1
Always worth asking init, just ordered them and a few other bits.
Post by scoobytoo on Jun 1, 2012 22:27:56 GMT 1
I always say, if you don't know just ask
Post by ducatidave on Jun 2, 2012 11:21:07 GMT 1
Can u change german klm in to uk this way ?
Post by midlifecrisisrd on Jun 2, 2012 11:40:50 GMT 1
Can u change german klm in to uk this way ? Yes as if you look at 160kph it should be in the same place as 100mph odometer will still read in km. done this a few times with ypvs kidney clocks. Steve
Post by midlifecrisisrd on Jun 2, 2012 11:42:35 GMT 1
The needle pulls off, make sure you pull from centre part tho OR it will snap! The decals are stickers. I had to sand the face down to just the original plastic so they illuminate correctly. I've got a picture when I did mine so I'll get off this iPhone and grab pc and upload a picky for you First set of N2 clocks I did I fitted white dials and never knew about sanding the faces and ended up with a ghost image shining through. Steve
Post by raven13 on Jun 2, 2012 12:31:03 GMT 1
i did a test run on a knackered rev counter last night. its really quite easy just do a little at a time and keep going round and round and round till you can ease it off.
Post by Deleted on Jun 2, 2012 14:00:41 GMT 1
hi there, just today i put a new tacho sticker face on, it was harder than i thouight it would be, but in the end it went well, heres some pics,
Post by ducatidave on Jun 2, 2012 16:21:06 GMT 1
Can u change german klm in to uk this way ? Yes as if you look at 160kph it should be in the same place as 100mph odometer will still read in km. done this a few times with ypvs kidney clocks. Steve Thanks steve
Post by adamp2006 on Jun 6, 2012 0:18:31 GMT 1
so didnt know norbo did stickers for clocks, so going to get a set of these as I'm part way through taking mine apart, great guide to sanding them down and getting a good result too , this is why i love this site :-)
