Post by oldelsieboy on May 20, 2012 14:38:21 GMT 1
Is the YPVS carb balance pipe, the part often replaced with a boost bottle.
Cheers
OEB
Post by flames on May 20, 2012 14:50:28 GMT 1
outer diameter from where it fits inside the rubbers?
Post by oldelsieboy on May 20, 2012 14:51:53 GMT 1
outer diameter from where it fits inside the rubbers? Diameter of the pipe that fits into the rubbers OEB
Post by flames on May 20, 2012 14:54:26 GMT 1
i make em 16mm
Post by flames on May 20, 2012 14:55:38 GMT 1
that is i measure them to be,not that i actually make em btw.
Post by oldelsieboy on May 20, 2012 16:10:03 GMT 1
Thanks OEB
Post by Tone on May 20, 2012 16:48:17 GMT 1
Just measured a spare and is as flames say's 16mm then you've got a raised "Ring" 10mm from the open ends that measures 18mm diameter. Tone
Post by oldelsieboy on May 20, 2012 17:04:27 GMT 1
