Post by marddy on May 16, 2012 19:32:42 GMT 1
Need help please...
I intend using a set of Wiseco Pistons in my RD350LC 4L0-01 model [non YPVS].
I understand that cast pistons require 60 to 65 micron clearance??? Since Wisecos are forged ones, what should be the clearance I should keep?
Post by 47x on May 16, 2012 20:01:26 GMT 1
i would stay clear of wiscos as there have been problems with the wrist pin coming out of them!!!!!i dont know of the clearance sorry.
Post by davey on May 17, 2012 8:10:55 GMT 1
sorry to jump in but what would you say apart from gen yam are a good piston.
thanks dave
Post by midlifecrisisrd on May 17, 2012 8:30:23 GMT 1
It's usually marked on the side of the box.
Post by 47x on May 17, 2012 10:50:41 GMT 1
hey dave,mitaka and art pistons seem to be ok,hth.
Post by davey on May 17, 2012 15:59:03 GMT 1
Thanks 47x, luck has it its what i just put in me 250.
Post by arrow on May 17, 2012 19:37:39 GMT 1
An ART piston is a genuine Yamaha piston.
Post by 47x on May 17, 2012 19:39:09 GMT 1
wondered why they were so much!!!!!!
Post by arrow on May 17, 2012 19:41:32 GMT 1
I have one in the for sale section, but no one seems to want it.
Post by 47x on May 17, 2012 19:57:39 GMT 1
how much?what size? is it for ypvs.ah,doesnt matter,i just seen how much it is
Post by arrow on May 18, 2012 6:30:07 GMT 1
how much?what size? is it for ypvs.ah,doesnt matter,i just seen how much it is The piston and rings alone would be £187 from Yamaha. That price is for a kit with circlips and gudgeon pin.
Post by 47x on May 18, 2012 9:25:19 GMT 1
then that is a good price your asking,but that is stupid money yamaha ask for it,i would rather use mitaka ones,they are good enough.
Post by happyrd on May 21, 2012 18:47:19 GMT 1
check out yamahararespares in Oz phil drummond he has .75 pistons [2]only @ 130 aus posted he has 1.00 mm pistons [2]rings and pins small end 260 aus or so. phildrum@bigpond.net,au the parts are genuine 4lo.
Post by slinger on May 22, 2012 14:10:02 GMT 1
i would stay clear of wiscos as there have been problems with the wrist pin coming out of them!!!!!i dont know of the clearance sorry. What a load of tosh lol. I use hundreds of Wiseco pistons and never had the wrist pin come out. The only reason one would come out is because the retaining clip is not installed correctly. 350=.076mm 250=.06mm
Post by marddy on May 22, 2012 15:35:09 GMT 1
Thanks Slinger.
Why is there a difference between LC350 and LC250 clearances for Wisecos?
At 0.76mm, will there be a clatter? Does it have to be run-in? If yes, then, what is the running-in speed and distance?
Post by 47x on May 22, 2012 17:08:10 GMT 1
its not a load of tosh at all....slinger,i dont talk tosh,just facts!!!!and the facts are that wisecos have had REPORTS of gudgeon pins coming out of there piston kits.maybe you aint heard of it over the pond m8,get facts before you condem it to....tosh!!!!,are you employed by a wiseco dealer by the way? ??
Post by midlifecrisisrd on May 22, 2012 17:10:53 GMT 1
Thanks Slinger. Why is there a difference between LC350 and LC250 clearances for Wisecos? At 0.76mm, will there be a clatter? Does it have to be run-in? If yes, then, what is the running-in speed and distance? Slinger was involved in my ypvs engine build and knows his stuff. He supplied me with wisecos and I have had no problems although not done a lot of miles. I would think the larger clearance on the 350 is down to the larger diameter and that it will expand more. As for clatter there is some noise when cold but nothing when warmed ( as you would expect once they have expanded ) It is still quieter than my old engine which ran fine with cast pistons. As for running in I was advised to do some heat cycles followed by some short runs holding it at 6k then allowing to completely cool. I did 6 15 mile runs which took it to around 90 miles then thrashed it. Now been thrashing it for over 100 miles with no issues. Steve Steve
Post by 47x on May 22, 2012 21:17:38 GMT 1
if he knows his stuff mlc,he should know about the problem with wiseco kits?but,then he supplies them!!
Post by slinger on May 22, 2012 22:49:37 GMT 1
if he knows his stuff mlc,he should know about the problem with wiseco kits?but,then he supplies them!! I am a Wiseco dealer from ATV,dirt bikes, road bikes,race bikes and marine engines. I've not been told by Wisceo or even heard of this "problem" with the wrist pins falling out. Until I see it or am informed by Wiseco it's just tosh. Just like they seize all the time.
Post by 47x on May 22, 2012 23:05:07 GMT 1
i thought you were a dealer!!!!!!LOL .a seizure can happen to any piston,not just wisecos!!!!but there have been reports of these pistons throwing there pins out,its not bullshit m8,i wouldnt say it for the sake of it.i agree that until wiseco say otherwise,then you got no reason to beleive this,but that does not mean it isnt true!!!!.but then would they say????maybe its crap circlips?i replied to a question,and said what i knew,its up to the person whether they take on board that info. regards
Post by slinger on May 23, 2012 1:11:30 GMT 1
I'm a dealer of many makes of pistons so I don't get the "dealer" thing. Cast pistons have there place just like forged and all have thier problems. What do you want, me to tell you about all the skirts that have bust of cast pistons.
It's just internet talk, maybe you could post the evidence of all these wrist pins falling out and who built the engine?
Post by slinger on May 23, 2012 1:17:01 GMT 1
Thanks Slinger. Why is there a difference between LC350 and LC250 clearances for Wisecos? At 0.76mm, will there be a clatter? Does it have to be run-in? If yes, then, what is the running-in speed and distance? Expansion rate between the two sizes, 250 smaller so don't expend as much as the larger 350 piston. You could go into the BMEP of the engine to determine the piston clearance, but what the fook do I know lol.
Post by 47x on May 23, 2012 12:14:25 GMT 1
like i said,i answered a question!!!!i dont want nothing of you m8,for sure!if i knew how to do the link i would but its on you tube,by a reputable tuner,and he wont use them because of these problems!!!like i said,its not bullshit!
Post by rdstars on May 23, 2012 20:01:56 GMT 1
Forums sure make me laugh at time's.
Post by rd350r on May 23, 2012 20:16:38 GMT 1
youtube video of engine tuner telling of his problems with Wiseco piston's, from 3.30min
Post by rdstars on May 23, 2012 21:07:33 GMT 1
Made me smile again,,,,,
Post by rdstars on May 23, 2012 21:21:37 GMT 1
It's cool, But a little advice, take Slingers words as Gospel, he is a real engineer
Post by 47x on May 23, 2012 21:33:28 GMT 1
like i said,i answered a question,,i only past on info that was said about problems with it,dont have any issue with his credentials!
