Post by captaincaveman on May 12, 2012 19:53:08 GMT 1
The 2 torsion bars that bolt to the bottom of the engine. There supposed to have some sort of washers right?
Well i don't have them so question is what do they do and do i really need them?
Also has anyone got a photo of the clutch arm so i can see what way it go,s back on?
Post by nikfubar on May 12, 2012 20:55:56 GMT 1
The 2 torsion bars that bolt to the bottom of the engine. There supposed to have some sort of add washers right? Well i don't have them so question is what do they do and do i really need the? WTF you on about please clarify
Post by Shytalk on May 12, 2012 21:19:28 GMT 1
The 2 torsion bars that bolt to the bottom of the engine. There supposed to have some sort of add washers right? Well i don't have them so question is what do they do and do i really need the? WTF you on about please clarify +1 ;D Name says a fair bit, don't you like these Saturday night posts.
Post by chamber66 on May 12, 2012 21:56:31 GMT 1
WTF you on about please clarify +1 ;D Name says a fair bit, don't you like these Saturday night posts. Honestly , he doesn't even drink
Post by marsbar350 on May 12, 2012 22:18:38 GMT 1
god hes funny ;D idiot abroad
Post by captaincaveman on May 12, 2012 22:19:28 GMT 1
Post by Tone on May 12, 2012 22:26:17 GMT 1
Post by captaincaveman on May 12, 2012 22:27:11 GMT 1
I have the bars but im sure there supposed to be some kind of half dished washers that go with them.
Question was do i need the washers? But if you don't know what im on about i guess its going to be hard to answer.
Post by arrow on May 12, 2012 22:30:13 GMT 1
The parts list for the 1986 F2 does show a plate washer between the bush of the torsion bar and the crankcase, part number # 92990-10600. Thats right, if the center bush is fitted to the underside of the motor without a flat washer the small contact area will go into the ally and it will be loose in no time.
Post by captaincaveman on May 12, 2012 22:36:01 GMT 1
Its the lc i have. I,l just got some large washers and use them.
Post by arrow on May 12, 2012 22:39:30 GMT 1
Its the lc i have. I,l just got some large washers and use them. Same issue with the LC as with the F2.
Post by Deleted on May 13, 2012 1:07:03 GMT 1
gday captain, sounds to me like you need a parts manual, i honestly believe i wouldnt stand a chance of getting mine back together without it, this is what you need imho, parts catalog, haynes manuel,genuine factory book and good advice from the lads here.
