Post by bluebellc on May 12, 2012 8:16:06 GMT 1
Hi, I'm looking for the right method to remove paint (not factory) from plastic bits. Thanks John.
Post by Fingermaus on May 12, 2012 15:55:23 GMT 1
i've gotta do sum side panels mesel soon so in the same boat, im planning on the 'elbow grease' method , 1000grit wet'n'dry an plenty of water, i wouldnt want to use anything more abrasive/corrosive on plastics, ;D That's the way I'd do it.
Post by rdstars on May 12, 2012 17:15:54 GMT 1
If it is side panels then maybe an idea just to give them a key and not remove all the paint as you will have to plastic primer them other wise for the paint to stick.
