Post by captaincaveman on May 10, 2012 15:02:36 GMT 1
In the middle of fitting a new loom its a genuine part but there are a few plugs that i can seem to find ou where they go to here's a few photos Im guessing this is for the rear end lights and indys? This plug comes from the cdi but cant find anywhere to plug it in to on the old or new loom? there's also a red and white single wire coming from the cdi, cant find a home for that either? Now this plug is from the new loom Any ideas?
Post by 47x on May 10, 2012 15:55:39 GMT 1
the red/white wire goes into cdi.,and the other plug,the stator,the 3 whites/blue wire plug into stator,you are right about rear lights/inicators.hth.richy
Post by mellow on May 10, 2012 16:14:13 GMT 1
YES YES AND YES
Post by captaincaveman on May 10, 2012 17:05:58 GMT 1
stator i dident think about that The red and white wire is coming out of the cdi where would that plug into?
Post by andyburts on May 10, 2012 17:47:32 GMT 1
stator i dident think about that The red and white wire is coming out of the cdi where would that plug into? it should plug into the stator wiring . have you fitted the engine yet ? if not thatll explain it :-)
Post by captaincaveman on May 10, 2012 18:57:52 GMT 1
Engines other side of the garage. How stupid to i feel now ;D
one other thing ive found the flasher unit and where it go,s but there a place directly under the coil for i can only think anther electrical box? Any ideas on what should be there?
Post by oldelsieboy on May 10, 2012 19:41:42 GMT 1
Post by captaincaveman on May 10, 2012 20:01:21 GMT 1
Yeah i asked the same question but the flasher relay that i was told about fits in front of the coil just behind the head stock. This part fits directly under the coil.
I could have the flasher relay in the wrong place but that would mean im still missing something else.
I,l get a photo should see what im referring to then.
Post by oldelsieboy on May 10, 2012 20:12:35 GMT 1
Yeah i asked the same question but the flasher relay that i was told about fits in front of the coil just behind the head stock. This part fits directly under the coil. I could have the flasher relay in the wrong place but that would mean im still missing something else. I,l get a photo should see what im referring to then. The flasher relay goes on the left hand side of the battery box OEB
Post by captaincaveman on May 10, 2012 20:17:45 GMT 1
Here a couple of photos
Post by oldelsieboy on May 10, 2012 20:22:16 GMT 1
Here a couple of photos The indicator cancel relay can be mounted on either of the 2 tangs under the coil, only one is used, the other is left vacant. OEB
Post by captaincaveman on May 10, 2012 20:44:12 GMT 1
That's good news, apart from spending most of this afternoon looking for something that doesn't exist lol
