Post by pedropete on May 10, 2012 9:43:46 GMT 1
Went to check the fuses today and found they are the old ceramic type,can anyone tell me if these are the correct type for the uk spec lc which i was lead to believe or were they fitted to euro spec,
Post by marsbar350 on May 10, 2012 10:34:40 GMT 1
dont think they are pete mines got the glass tube type
Post by pedropete on May 10, 2012 11:37:18 GMT 1
mmm is yours a uk bike ,i know there is a fuse box conversion available has yours had that!!
Post by marsbar350 on May 10, 2012 11:40:25 GMT 1
mines a uk bike as long as they are the right amp fuses cant see it matters
Post by pedropete on May 10, 2012 11:43:52 GMT 1
cheers mate ,point taken things look a bit corroded in there thats all,i might change it as a matter of caution
Post by 47x on May 10, 2012 11:49:02 GMT 1
hi,anyone got a f2 fuse box cover??sorry to hijack thread!!
Post by bigal1 on May 10, 2012 13:10:55 GMT 1
if you go to helfords you can a new blade fusse box and all the fitting for about £15 and its realy easy to do just chop off the wirers on the old box and crimp new spade fitings ..simple's ... by the way if your out and about and one of the old fusses blow and you have no spare at least with the new blade fusses you can go into most petrol stations and buy easy
