Post by captaincaveman on May 9, 2012 19:22:36 GMT 1
Can you change the clutch push rod seal from the out side? secondly there's quite a bit of side ways free play on the front sprocket.
I can pull it in and out a couple of mill is there supposed to be a bush or something on the inside to take up the slack?
Post by arrow on May 9, 2012 19:45:55 GMT 1
Pulling it in and out is not side ways play, can you clarify that one please.
Post by captaincaveman on May 9, 2012 19:47:56 GMT 1
you can grab the sprocket and pull it towards you and push it back. As you look at the engine side on.
Post by arrow on May 9, 2012 19:57:48 GMT 1
you can grab the sprocket and pull it towards you and push it back. As you look at the engine side on. A small amount here is normal, even when the nut is tight. Can you change the clutch push rod seal from the out side?Yes, no problem.
Post by captaincaveman on May 9, 2012 20:26:19 GMT 1
ok thanks for that.
