Post by captaincaveman on May 9, 2012 17:53:22 GMT 1
The seal that fits into the casing. Witch way should the spring side face?
Post by arrow on May 9, 2012 18:05:50 GMT 1
Spring facing into the pump. Fit it with the plunger shaft already in place held in with washers and a nut or you will fook the seal on the plunger shaft side pin.
Post by captaincaveman on May 9, 2012 19:19:15 GMT 1
thanks for that
