Post by tout on May 9, 2012 12:09:16 GMT 1
Not happy with my oil pump ? on my mk1
cant see it stroking on tick-over ? put a finger on pulley towards pump,to put some pressure/load on it and you can feel a weak stroke.
Go premix ? 33:1 sound about right ?
Post by mellow on May 9, 2012 16:16:21 GMT 1
it hardly moves on tickover have a look at the other oil pump threads in 350 and advice sections that are currently active.ul find ur answers
Post by tout on May 9, 2012 17:04:33 GMT 1
Mr Mellow, are you suggesting "stroke shims" ?
is anyone able to give a breif outline to doing this procedure please,possibly with the aid of a piccy......
I have previously run premix out of precaution on any 2 stroke with an untrusted pump Ta T
Post by arrow on May 9, 2012 17:20:23 GMT 1
Mr Mellow, are you suggesting "stroke shims" ? is anyone able to give a breif outline to doing this procedure please,possibly with the aid of a piccy...... I have previously run premix out of precaution on any 2 stroke with an untrusted pump Ta T I will put a post up in the tech section. Now done.
Post by mellow on May 9, 2012 21:26:34 GMT 1
Cheers arrow
Post by tout on May 10, 2012 17:32:56 GMT 1
PM`d Arrow thanking him for the guidance.
Previously, if no spindle movement at tickover I have assumed (incorrectly) that the pump is jiggered ! and gone to premix as the solution.
Thanks Again , Tout
Post by bertiemollie on May 12, 2012 6:16:39 GMT 1
Hi Tout,
Looking at mine today you can see it moving on idle.
Cheers
Andrew
