Post by ngordoncrosby on May 8, 2012 22:24:24 GMT 1
On rainy days my green neutral light comes on not a big deal but I spose there must be some water that gets in there somewhere ,bit afraid to open in case opening a can of worms.has anyone else had this?? ::)
Post by midlifecrisisrd on May 9, 2012 9:45:57 GMT 1
Neutral light works simply by the switch grounding out the circuit so coming on when wet means it is being earthed somewhere.
Think a dose of wd40 is needed to dispel water and check and grease the wire at the switch behind the sprocket cover.
Post by ngordoncrosby on May 9, 2012 12:10:08 GMT 1
Cheers for that
