Post by hardhatharry on Apr 18, 2012 0:19:56 GMT 1
Hi Im new to YPVS ownership and I picked up a 1986 F2 31K last weekend.
Everything looks ok except for the forks which are really soft and deck out at the slightest downward force.
I am about to strip them down and rebuild with 15W fork oil but I was wondering does anyone in the UK do emulators as they all seem to be in the US?
Thanks for any info, hopefully MOT this weekend!!
Post by flames on Apr 18, 2012 5:15:09 GMT 1
hi,welcome to the site dude.dont forget to get some pics up of your ride.sorry i cant help with your question,i dont know what an emulator is,but someone will be along soon that knows im sure.
Post by oldelsieboy on Apr 18, 2012 6:34:08 GMT 1
Post by Shytalk on Apr 18, 2012 7:46:33 GMT 1
If they are that soft you'd be better fitting Hagon progressive springs when you change the oil, rather than the other bits.
Post by Norbo on Apr 18, 2012 7:46:57 GMT 1
Hi mate and welcome to the site . I think once you have fitted new seals it will be a lot better . I normaly addn a little more oil to each leg and for theat extra bit of firmnes i cut a old clutch spring in half and place it on a top hat washer on top of the fork spring . That sorts it out a treeet and costs nothing .
Do you have a pic of your new steed.
OEB How about putting the info on hear mate
Post by hardhatharry on Apr 18, 2012 12:19:13 GMT 1
Hi all,
Thats for the replys
Norbo,
I assume all will become clear on the size of the top hat washer when I open up the forks and I have a lathe to create some but is the clutch spring a YPVS clutch spring or any?and what length?
The bike is on the bench now so will post pictures once the forks are done unless I can find the pictures the seller posted online
Thanks
Post by hardhatharry on Apr 18, 2012 12:19:33 GMT 1
Oh and whats OEB?
Post by oldelsieboy on Apr 18, 2012 18:11:06 GMT 1
oeb is member called OldElsieBoy,his name is steve,and knows EVERYTHING about rd"s. Doesnt say that on my birth certificate OEB
Post by hardhatharry on Apr 18, 2012 18:25:08 GMT 1
Well forks are out and oil dropped into a bucket. The Oil is relatively new and there is no leaks on the seals so I'll put 15w oil in and the mod suggested by Norbo and see how I get on.
One thing I did notice was there was no air in the "air assisted bit" I believe it should be 2 PSI and I assume a footpump would do to pump them back up.
Post by 47x on Apr 18, 2012 18:44:38 GMT 1
yes thats right,but be careful you dont pump to much in,as a footpump cant messure 2 psi!
Post by hardhatharry on Apr 18, 2012 19:13:17 GMT 1
bugger, didnt think about that, wonder if I can sneak them to the local petrol station and use their air machine
Post by mellow on Apr 18, 2012 19:14:15 GMT 1
isnt 5psi standard you should really use a correct pump for this small psi.you could easily put too much in with footpump so go slowly
Post by hardhatharry on Apr 18, 2012 19:26:52 GMT 1
I have dug the book out, 5.7psi rider only, 8.5 rider and luggage
Post by mellow on Apr 19, 2012 8:57:57 GMT 1
i thought so.i definately would not use a garages airline.too much pressure
Post by bigal1 on Apr 19, 2012 9:27:24 GMT 1
also check the size of the spings as they may have compressed all the springs should be a certain lenth
Post by woodentopp on Apr 19, 2012 11:08:17 GMT 1
If you want to uprate your forks, Maxton do a conversion that keeps the original look.
Post by hardhatharry on Apr 19, 2012 15:12:32 GMT 1
Its going to be a hybrid eventually so I dont want to spend loads on suspenion I will be binning in the winter.
Post by Norbo on Apr 20, 2012 7:50:55 GMT 1
I have put a couple of springs cut down and a couple of top hat washers in as well just sit them on top of your springs and they will improve it a bit. but by the sounds of it your springs ar well past best and need replacing . Still in the meen time im shure this simple mod will help .
Post by midlifecrisisrd on Apr 20, 2012 7:57:18 GMT 1
I remember " back in the day " being advised to put 4 2 pence pieces on top of each spring to stiffen them up. Worked well as you could use them like shims to adjust them, fit in perfectly.
Post by 47x on Apr 20, 2012 17:15:21 GMT 1
oeb is member called OldElsieBoy,his name is steve,and knows EVERYTHING about rd"s. Doesnt say that on my birth certificate OEB sorry OEB :-Xi got you mixed up with midlifecrisis
Post by Deleted on Apr 21, 2012 9:38:51 GMT 1
Apart from emulators, I have tried everything but I found progressive springs to be the cure for my F2's front end evils. The harder I brake, the better they work ;D I run at atmospheric pressure as well
paulo
Post by paulo on Apr 21, 2012 20:17:11 GMT 1
I packed mine up with about 30mm worth of washers super glued together - saved on new springs. I use a bicycle pump and a digital gauge, be very careful, only takes about 3 pumps. Running mine at approx 8psi and have no complains from 30 year old suspension. Also using 15w oil - nice and firm now ;D.
