Post by captaincaveman on Apr 16, 2012 22:01:21 GMT 1
Told you i,d have loads of questions ;D The wheels on my bike have been powder coated in the past. I,d like to get them back to the metal and repaint them. What would be the easiest way of doing this? any ideas.
Post by chamber66 on Apr 16, 2012 22:08:58 GMT 1
Told you i,d have loads of questions ;D The wheels on my bike have been powder coated in the past. I,d like to get them back to the metal and repaint them. What would be the easiest way of doing this? any ideas. those coaters you recomended did a cracking job on my wheels £30 each
Post by scoobytoo on Apr 16, 2012 22:10:53 GMT 1
i used nitromore for some of my powder coated parts, needed a couple of goes but got it off !!
Post by Norbo on Apr 17, 2012 8:31:28 GMT 1
I use Nitromorse it takes ages and a real hassle but it can be done. Some powdercoaters have a did they singa wheel in to remove the old stuff then they blast the wheel .
Post by rdstars on Apr 17, 2012 9:58:34 GMT 1
I've been using Nitromorse on my engine cases and getting know where BUT when I used it on my frame it seem to work, maybe my frame has been painted before not sure.
I'll probably be trying a bit on some wheels soon as I may just do a polish & powder coat.
Post by arrow on Apr 17, 2012 16:47:33 GMT 1
Nitromorse is a lot weaker than it used to be (despite what it says on the tin) due to European legislation.
Post by Witterz on Apr 17, 2012 22:09:41 GMT 1
I would do a small test section first as I was under the impression that the powder coaters tend to blast the wheels to rough them up so the powder coating adhere better. You could end up in a position where it would be very hard the polish up the wheels rims after the coating has been removed. Don't want to put you off, just be wary before coating the whole wheel in nitro morse to find you have replaced one issue with another. Best do a little test section around the hub to see what the surface looks like underneath. If too bad, you can just touch up with a bit of paint and no one would notice it so much.
Post by chamber66 on Apr 18, 2012 23:15:04 GMT 1
Just take it to your powder coaters, let them deal with stripping it and let them do the work
Post by davey on Apr 19, 2012 15:47:54 GMT 1
try brake fluid ,,, every time i do my brakes i f--k some paint somewhere. durrrrrr
Post by Deleted on Apr 19, 2012 22:57:40 GMT 1
LOL,
Post by ianmac on Apr 21, 2012 9:08:51 GMT 1
New Nitromors is simply crap.......Wouldn't take the skin of a rice pudding......
Post by rdstars on Apr 21, 2012 10:25:55 GMT 1
I rang someone up local and they wanted £100 to Vapour blast my crank cases. Sod that I could buy my own setup.
Post by skaterboy on Apr 21, 2012 10:59:17 GMT 1
Rdstars Try a company called ELTEC in Iver Uxbridge LONDON around £30 to vapour blast engine cases. A guy called Elliot runs it very helpful and knows what he is taking about.
Post by rdstars on Apr 21, 2012 11:24:42 GMT 1
There is then postage etc, jobs like this you rely need to get done local or do yourself. for the cost I may just get myself setup with the jet wash and wet blasting.
