Post by mudmover on Apr 5, 2012 9:39:07 GMT 1
OK after all the advice not to up JET my LC but to sling the pod filters I painfully went the route of getting and airbox/ filter/ rubbers/ clips ( £80 lighter) and fitted it all....
The bike now sounds so muted I prefer the PODs sucking..BUT my concern is that the bike is hardly smoking now once warmed up..Ive checked the plugs and they are a perfect browny colour so oil must be getting there..
I'm just very uncomfortable with the lack of 2 smoke....Can I turn up the pump ( BTWE you can see oil moving thro clear pipes) or should I just syring a blob into tank..if so how much ?
Cheers MM
Post by flames on Apr 6, 2012 9:25:21 GMT 1
i wouldnt of thought that changing from pods to airbox wouldve made any differance to the amount of oil to fuel mixture.was the pump adjusted when you fitted pods in the first place? im sure i saw a post on here ages ago about how much oil should flow per minute.but i cant find it.if u find that u could run on premix for a bit and measure what the pump is flowing.
