Post by marsbar350 on Apr 3, 2012 22:29:51 GMT 1
hi guy recently rebuilt my engine neutral and indicators were working fine.now indicators flash apart from the idiot lights neutral light was working too.now that doesnt come on all were workin well after the rebuild.neutral wire good and in the right place. any ideas
Post by JonW on Apr 4, 2012 0:35:07 GMT 1
check all the connections, especially the earths. This kind of problem can leave you running around for ages and then you suddenly get it sorted. check the bulbs in teh dash as well, but my feeling is its a connector block thats unseated.
Post by Tone on Apr 4, 2012 10:46:25 GMT 1
As jonw has said check all connection but looking at the wiring diagram there is a multi plug in the headlamp that does the neutral light , indicator warning lights and high beam warning light so have a look there to make sure it's making a good contact. Tone
Post by Norbo on Apr 4, 2012 11:45:17 GMT 1
all so double cheque the earths
Post by marsbar350 on Apr 4, 2012 14:33:54 GMT 1
thanks guys will whip the headlight off and a have peer in
Post by marsbar350 on Apr 4, 2012 16:39:17 GMT 1
found the problem guys.a loose indicator wire ;D thanks
