Post by marknutt on Apr 3, 2012 19:29:41 GMT 1
Can anyone help!
When I bought my RD350 LC 4l0 it had a Michelin front tyre and Dunlop rear.
I want to replace the rear Dunlop with a Michelin, on the Dunlop tyre fitted it says 110/80-18
Will a Michelin 3.00-18 be the same tyre size and will it fit my rear rim
Any advice would be greatly received
Thanks
Nutty
Post by lcowner on Apr 3, 2012 20:06:21 GMT 1
if its standard swinger biggest tyre that will fit is 120,90,18 and 90,90 18 front
Post by flames on Apr 3, 2012 20:09:26 GMT 1
3.00-18 is front tyre size,3.50-18 is the equivelant of a 110 width tyre.
Post by oldelsieboy on Apr 3, 2012 20:09:31 GMT 1
Can anyone help! When I bought my RD350 LC 4l0 it had a Michelin front tyre and Dunlop rear. I want to replace the rear Dunlop with a Michelin, on the Dunlop tyre fitted it says 110/80-18 Will a Michelin 3.00-18 be the same tyre size and will it fit my rear rim Any advice would be greatly received Thanks Nutty Tyre sizes originally fitted were 3.00-18 front & 3.50-18 rear. HTH OEB
Post by marknutt on Apr 3, 2012 20:21:21 GMT 1
Thanks for that
Is M45 type tyre a decent enough Michelin rated tyre to use.
This is what is on the front
Nutty
Post by Norbo on Apr 4, 2012 11:49:09 GMT 1
Hi mark welcome .
You will be with the M45 if thats what you have on the front .
r1olly
Post by r1olly on Apr 4, 2012 13:14:26 GMT 1
i got a 130\70\17 in a 4lo swing arm, with rgv wheel, with about 10mm clearance each side, so id say 130 is max in a stock swing arm. olly.
r1olly
Post by r1olly on Apr 4, 2012 13:16:21 GMT 1
Post by 47x on Apr 4, 2012 16:34:15 GMT 1
nice bike olly!!
