Post by gerumgoin on Mar 28, 2012 21:18:43 GMT 1
Hi all,so I'm doing a UK model rd125LC 2hk but with this model not having a working power valve whats the best loom to use on the bike,i don't have a 2hk one,but i do have a 1GU loom,can i use this one or would a 1gm loom be better.or must i get a 2hk loom??
Post by mellow on Mar 28, 2012 22:24:26 GMT 1
Hi. do you mean 2HK Im pretty sure the 1GU loom will be fine,as long as you dont want to run the powervalve. I believe it may be fitted but just locked open.Have you checked 1GU is the prefix for swiss model and 1GM is english model. The only difference in the working powervalve loom is the extra section at the rear for the control unit if i remember correctly May be a couple of different colour wires but pretty obvious where they plug in I do have a full colour wiring diagram here if you need any help
Post by Norbo on Mar 30, 2012 10:18:30 GMT 1
its all been said above you will be fine with ether non ypvs loom if your not running a working valve.
Post by gerumgoin on Mar 31, 2012 18:50:48 GMT 1
thanks for info guys. ;D
