Post by lcrider on Mar 22, 2012 12:03:05 GMT 1
You will be bettor of doing a test spray to get a match but frankley id spray everything no matter what then you know its alla match
Post by Norbo on Mar 22, 2012 21:16:07 GMT 1
I look forward to seeing how it turnes out .
Post by twostroker on Mar 22, 2012 21:42:19 GMT 1
yamaha clean white is the colour your looking for. if your going to use a similar car colour opel/vauxhall casalanca white isnt miles off and its a damn sight closer match than good old ford diamond white which commonly used its a dirty creamy white seen on most transits etc (depending on varient/manafacter)..
Post by LC_BOTT on Mar 27, 2012 17:27:40 GMT 1
Hi, I've never used filler primer before, is it necessary, or just a very thick paint, does it do any more than several coats of normal primer?? hoe easy is it to spray, are you using cans or a gun??
