Post by Bazille on Mar 11, 2012 19:08:46 GMT 1
Hi just removed my baffles from my 350lc allspeeds and one of the baffle tubes is rusted in half!! Does anybody know where i can get new baffles or 25mm diam perforated tube so i can make some new ones??
cheers Colin
Post by billyboy on Mar 11, 2012 20:23:35 GMT 1
if they were made from stainless it would never happen. you may be better off buying some sheet and rolling and welding to the diameter you want. otherwise get in touch with gibsons who are now making them
Post by Bazille on Mar 11, 2012 20:32:31 GMT 1
billy, thanks for that, ,just searched gibsons and sent them a message
cheers colin
Post by arrow on Mar 11, 2012 20:34:58 GMT 1
Norbo has the baffles (2 types) in his shop.
Post by Bazille on Mar 11, 2012 20:38:42 GMT 1
cheers arrow, will also check that out thanks
Post by Bazille on Mar 13, 2012 22:15:29 GMT 1
been in contact with Gibsons and have ordered a pair of baffles from them!
Thanks for your help
hazey
Post by hazey on Mar 13, 2012 23:48:26 GMT 1
Made these for my 400 large can allspeeds,could not get 25mm stainless perforated so had to cut down 40,jubilee clipped it untill desired size then welded,now has 25mm stainless outlet as gen stingers were to small in dia. Oh and a couple of designer egg cups had to be sacrifised for the job And they now come straight of the the end of the chamber rather than well within poor quality old mobile pic
Post by billyboy on Mar 14, 2012 21:13:39 GMT 1
cracking job there , the extra bit inside the baffle cone just adds to the silencing a bit
chez
Post by chez on Mar 14, 2012 22:22:00 GMT 1
been in contact with Gibsons and have ordered a pair of baffles from them! Thanks for your help what did they charge you iam in the same boat i need two as well
Post by Bazille on Mar 15, 2012 22:29:18 GMT 1
chez, £25 each, should hopefully get them tomorrow (fri), will let you know how they are cheers colin
