Post by marsbar350 on Feb 26, 2012 23:16:57 GMT 1
you know when you buy a new chain its got all the manufacturers goo on it are you supposed to remove it or just apply chain lube on top
Post by arrow on Feb 26, 2012 23:39:29 GMT 1
I have always cleaned it off. Then they get the castrol racing chain lube treatment.
Post by mellow on Feb 26, 2012 23:43:03 GMT 1
depends what conditions you ride in and miles etc i normally wipe the excess off then run it for a while then when i think i need to lube it on goes the PJ1 Blue Label
Post by marsbar350 on Feb 26, 2012 23:45:00 GMT 1
good advice lads looks like a spray of condom lube then
Post by r1beater on Feb 27, 2012 13:22:14 GMT 1
I use dry chain lube its worth a try no mess!
phil38
Post by phil38 on Feb 27, 2012 13:57:48 GMT 1
depends what conditions you ride in and miles etc i normally wipe the excess off then run it for a while then when i think i need to lube it on goes the PJ1 Blue Label Wipe off the excess, but don't degrese it. O-rings don' like most de-greasers (inlcuding petrol/ brake cleaner). If you want to run dry lube, it's probabaly worth using a proper chain cleaner to get the waxy stuff off first.
