Post by alext on Feb 26, 2012 17:16:31 GMT 1
how do I stop the head gasket dribbling coolant??
done a search and its still not clear - A genuine gasket is one option, and a very thin smear of gasket sealer is another .
whats the general consensus??
Post by oldelsieboy on Feb 26, 2012 17:18:44 GMT 1
how do I stop the head gasket dribbling coolant?? done a search and its still not clear - A genuine gasket is one option, and a very thin smear of gasket sealer is another . whats the general consensus?? Have you re-torqued the head after a couple of heat cycles? OEB
Post by mellow on Feb 26, 2012 17:54:08 GMT 1
i use genuine gasket with a smear of sealant when my one seeped from centre of head after re tourqing
Post by bare on Feb 26, 2012 19:14:07 GMT 1
Remove the head, clean everything. Respray the Gasket with Metallic coloured Laquer (be certain it IS laquer in silver/copper) Then refit. Poor mans' Permatex Copper Coat Gasket spray.. yes it does work. Unless there are other issues ie: damaged gasket, warped head, missmatched cyls etc.
Post by arrow on Feb 26, 2012 19:17:18 GMT 1
Radweld sorted mine, not leaked since.
Post by gazzatt2 on Feb 26, 2012 22:25:24 GMT 1
on mine it was the hose going to the back of the head weeping and running round the head joint and dripping off l/h side (bike only has side stand)
