Post by rdstars on Feb 24, 2012 22:07:40 GMT 1
Hey all, how many have used the digital Vapor Dash, thinking of getting one to tidy up my front end.
Plenty on ebay but where is the best place to get them from, as standard do they come complete with everything or what else is needed to function on the RD350.
Guessing the original Temp sender on the RD can be used?
Speedo, guessing the magnet option is the best way, where and how did you mount yours?
Anything I missed out?
Cheers
Post by pepsisteve on Feb 24, 2012 22:36:26 GMT 1
fitted one to my rgv, doesnt take long, i used a speedo extender as i ran my pick up from the rear wheel to keep the front end tidy. nice bit of kit, i did run it on my lc for a while but i think one of the things about an LC is the original clocks. the vapors make the front end look a bit empty.
slot
Post by slot on Feb 24, 2012 22:51:15 GMT 1
Hi mate Try looking at the KOSO clocks, there a bit more tricky than the Vapors, i had a RX model on a project bike, a bit more expensive thou but you'll see the reason why once you've seen one Dave
Post by rdstars on Feb 24, 2012 23:02:17 GMT 1
Any photos of some digital dash fitted to naked RD, just to give me an idea.
Cheers
Post by oldelsieboy on Feb 24, 2012 23:26:25 GMT 1
Any photos of some digital dash fitted to naked RD, just to give me an idea. Cheers I fitted a vapour to my 4L0 & as previuosly mentioned just didnt look right, only stayed on for a week or two replaced it with the standard clocks. OEB
Post by Trubrit on Feb 25, 2012 8:13:55 GMT 1
I To tried the vapour dash On A Special found it a bit to small , Ended up coming up with these ......Still got the vapour kicking around if you wanted a cheap one........... . .
Post by lovelydog on Feb 25, 2012 8:26:15 GMT 1
Love those KOSO clocks,that looks very cool. Shall pass this on to my son,he's always looking at trick bits for his Bandit 600. Very nice job you've done there mate.
Post by vin on Feb 25, 2012 8:49:36 GMT 1
Still got the vapour kicking around if you wanted a cheap one........... I may be interested if rdstars isn't mate?
Post by lb on Feb 25, 2012 10:17:19 GMT 1
I Man,what the 'ell those triples off?
Post by rdstars on Feb 25, 2012 11:50:56 GMT 1
My front end is a little more compact with cliponns, going all stealth black so should blend in ( hopefully ) Little like Vin's old RD. trubrit you got pm fella
Post by lcowner on Feb 27, 2012 14:39:15 GMT 1
may have these koso db02r dig dash for sale pm me if interested comes witht the 4lo bracket i made up to so bolt straight on
