Post by lcowner on Feb 22, 2012 23:30:19 GMT 1
widest tyre that will go on a vj22 rear wheel?
dex46
Post by dex46 on Feb 23, 2012 21:28:12 GMT 1
You will get a 160 on there but i would stay with a 150-60-17 that is the standard size
Post by midlifecrisisrd on Feb 24, 2012 9:16:54 GMT 1
A 150 is as big as you can go.
160 rubs on the chain. That's why I nearly went down the route of using a GK76 GSXR wheel as the sprocket sits 5mm further out allowing a 160 to fit but unfortunately the offset front sprocket to match won't fit under an Lc case so match abandoned for now.
Post by midlifecrisisrd on Feb 24, 2012 9:18:09 GMT 1
150-60-17 i think Is it a 5.5 inch rim ? It's a 4.5 inch rim. Steve
Post by lcowner on Feb 24, 2012 9:41:40 GMT 1
cheers 150 it is then
Post by guslogi on Feb 26, 2012 17:08:26 GMT 1
150-60-17 i think Is it a 5.5 inch rim ? It's a 4.5 inch rim. Steve this its a 4.5 inch rim. yes people run 160 on them but not on lc's
Post by JonW on Feb 26, 2012 22:39:55 GMT 1
everyone i asked says the 160 isnt nice to use on the 4.5inch rim, so yeah like everyeone else says stick to the 150.
