Post by rostrumorhospital on Feb 21, 2012 21:01:10 GMT 1
With the rgv forks/swinger etc getting increasing more expensive/hard to come by, I'm looking at other options, has anyone any experience with the zxr 400 as a Donner bike and are there any major problems compared to the rgv, cheers
Post by soccersmyth on Feb 22, 2012 22:23:39 GMT 1
There's deffo been zxr front end in the LC.
Not sure about the back.
Get in touch with Nigel Kimber of NK Racing if you don't get the answers you need here.
But as with all things.
If you use a big enough cheque book, it'll be made fit.
Post by Norbo on Feb 24, 2012 10:20:39 GMT 1
Post by rdstars on Feb 24, 2012 11:36:42 GMT 1
Front end is easy enough, a simple spacer under the bearing and weld in ( make lower ) the stop lock. Then there is the hard bit's like getting the clocks to mount neatly or use alternative clocks, headlight, cable routing, ignition switch. ZXR mudguards are like rocking horse poo. The rear end has been done a few times before, you got the problems of it's too wide, chain alignment, shock link/mount etc. Also if there is enough clearance for the exhausts. Sounds quite simple on paper Keeping it neat is the hard bit. If I was to build another RD it would be an original F2 but with a different rear wheel & shock, and a RWU front end.
dex46
Post by dex46 on Feb 24, 2012 21:49:54 GMT 1
Hi Mate Nc29 arm's are alot cheaper than the Rgv arm and easyer to come by that was the main reason ive used one you can check my bike out in the rebuild section under Lc hybrid build so far
Post by rostrumorhospital on Feb 25, 2012 21:56:32 GMT 1
thanks for the info guys, the quest goes on for the right machine, dex46 - your bike really does look the business, keep up the good work
