Post by millesteve on Feb 16, 2012 18:45:41 GMT 1
can anyone tell me what is involved in fitting 31K ypvs engine in my 4L1 frame, what mods do i need to make how to wire up power valves ect the engine i have had been fitted in a quad and the tacho drive had been removed including the shaft in the engine so i will need to reinstate these where is the best place to go for such parts and gaskits
dex46
Post by dex46 on Feb 16, 2012 21:39:41 GMT 1
Hi mate engine fit's straight in you will need the full 31K loom and electric's you can mount the servo motor under the coil where you plug in the 4L1 switchgear and if my memory serve's me right you need to change the spacer behind the front sprocket from 31K to 4L1/4Lo so the chain run's true im sure that is right but it has been over 20 year's since i done this conversion
Post by mellow on Feb 16, 2012 23:10:42 GMT 1
Hi steve and welcome. Do i know you? not from kent are you m8 ;D
Post by millesteve on Feb 16, 2012 23:14:23 GMT 1
yes mick it is mille from invicta
