Post by mrmeez on Feb 15, 2012 4:41:50 GMT 1
Hi Guys, Just purchased the below Gear Change Shaft for an RZ 350. I am told it will also fit an RD 350 LC (1980) model as well! They look indentical except a small notch in the end spline. Part numbers are very similar except the 1st few numbers Can somene please confirm that it will fit into an RD LC? RD LC Part Number: 4L0-18101-00 RZ Part Number: 2GU-18101-00 Also does nayone know whether the Oil Seal will be ok of an RZ? RZ Gear Change Shaft Oil Seal Part Number: 93102-12321 Cheers Guys! Mr.Meez Attachments:
Post by oldelsieboy on Feb 15, 2012 7:38:52 GMT 1
Hi Guys, Just purchased the below Gear Change Shaft for an RZ 350. I am told it will also fit an RD 350 LC (1980) model as well! They look indentical except a small notch in the end spline. Part numbers are very similar except the 1st few numbers Can somene please confirm that it will fit into an RD LC? RD LC Part Number: 4L0-18101-00 RZ Part Number: 2GU-18101-00 Cheers Guys! Mr.Meez Same part, 4L0 number is superseded by 2GU OEB
Post by mrmeez on Feb 15, 2012 13:56:51 GMT 1
Thanks Heaps for That! ;D
So im guessing the seal will be ok too? THe part number is listed below and it says it would suit a heap of other yamahas too!
Must be!
Thanks again!
Post by bigal1 on Feb 15, 2012 15:26:09 GMT 1
same part ...i have just done1 ona 350rz it was leaking around the seal we fitted a new seal but it still leaked ..new 1 fitted no leaks ..jobs a good en ..
