pre mix
Feb 14, 2012 17:37:06 GMT 1
Post by shane2011 on Feb 14, 2012 17:37:06 GMT 1
ive have a 350lc and i am going to pre mix what is the best mix? and what is the best oil to use?
pre mix
Feb 14, 2012 17:41:33 GMT 1
Post by lcowner on Feb 14, 2012 17:41:33 GMT 1
this is a real can of worms! 33-1 ratio is what i use
pre mix
Feb 14, 2012 19:23:33 GMT 1
Post by lcrider on Feb 14, 2012 19:23:33 GMT 1
6 FL oZ to a 4.5 L i was told for a road bike and 7 for a race bike .
higgsy
pre mix
Feb 14, 2012 20:30:29 GMT 1
Post by higgsy on Feb 14, 2012 20:30:29 GMT 1
I run my race YPVS/LC on 33-1 using Gulf fully synthetic. Whan I ran my 400 on the road it was on 25-1 (made it easy to measure fo a tank full) on Silkolene comp2/Putolene semi synthetic - no apparent wear after 10,000 odd miles.
So if your planning on using a fully synthetic, then 30-1 is probably a good compromise, you should really be using an oil designed to be pre-mixed btw, not all are
Best oil? Now that is a real can of worms!!!
pre mix
Feb 14, 2012 20:40:00 GMT 1
Post by arrow on Feb 14, 2012 20:40:00 GMT 1
6 FL oZ to a 4.5 L i was told for a road bike and 7 for a race bike . For anyone wondering that works out to 25.36:1 or 21.74:1 for a race bike.
pre mix
Feb 15, 2012 20:19:34 GMT 1
Post by barbarossa on Feb 15, 2012 20:19:34 GMT 1
Glad to see someone else is going down the pre-mix road. My RZ250RR - see many old posts on this subject - now runs premix @32-1. My oil pump cable snapped which buggered an engine which had recently been rebuilt - meaning another expensive rebuild. Never again. I KNOW Yamaha spent squillions developing oil pumps. I KNOW a properly adjusted pump theoretically delivers the correct amount of oil over a wide range of engine revs. I also know that if the oil pump cable snaps, it costs a few hundred quid to rebuild the engine. And I also know that when I put oil with the petrol, I KNOW the oil is getting to the engine. Don't forget to go up one size on your main jet.
pre mix
Feb 15, 2012 20:36:33 GMT 1
Post by bare on Feb 15, 2012 20:36:33 GMT 1
I run Both :-) Pump and premix. a) to get the mix up to 24:1 b) as insurance. Also doing this means I only have to carry a smallish amount of premix oil.
pre mix
Feb 15, 2012 20:42:02 GMT 1
Post by arrow on Feb 15, 2012 20:42:02 GMT 1
I run Both :-) Pump and premix. a) to get the mix up to 24:1 b) as insurance. Also doing this means I only have to carry a smallish amount of premix oil. Can I ask what ratio you are pre-mixing to then ?
pre mix
Feb 15, 2012 20:58:24 GMT 1
Post by midlifecrisisrd on Feb 15, 2012 20:58:24 GMT 1
I run Both :-) Pump and premix. a) to get the mix up to 24:1 b) as insurance. Also doing this means I only have to carry a smallish amount of premix oil. Exactly what I am doing now for similar reasons as well as stopping the tank rusting. Steve
Post by shane2011 on Feb 16, 2012 2:26:26 GMT 1
Thanks a lot for all the info very helpful!!
pre mix
Feb 16, 2012 16:29:29 GMT 1
Post by ianboom on Feb 16, 2012 16:29:29 GMT 1
Another different answer, 40:1 on rock oil fully synth-never needed to upjet for the premix!!
pre mix
Feb 16, 2012 21:33:17 GMT 1
Post by twostroker on Feb 16, 2012 21:33:17 GMT 1
ive previously used 40:1 in a few bikes with no problems.
pre mix
Feb 16, 2012 23:44:09 GMT 1
Post by LC'Adam on Feb 16, 2012 23:44:09 GMT 1
40:1 I would say is plenty if your using a good oil (castor/ester is the best) any more and it won't get completely burned and foul up your plugs on cold starts and clog everything up. Always used 40:1 on all my bikes and never had a seizure............. yet lol
pre mix
Feb 17, 2012 11:30:50 GMT 1
Post by shane2011 on Feb 17, 2012 11:30:50 GMT 1
looks like 40:1 mix is the top answer thanks all for the help!!
pre mix
Feb 17, 2012 17:15:34 GMT 1
Post by 47x on Feb 17, 2012 17:15:34 GMT 1
yep,i would say 40-1 is the best way to go.at the end of the day at least u know your motor is getting oil!!!!
pre mix
Feb 18, 2012 23:48:16 GMT 1
Post by arrow on Feb 18, 2012 23:48:16 GMT 1
looks like 40:1 mix is the top answer thanks all for the help!! I know modern oils are better and the people that have posted here had no problems. But for what its worth a 350 lc with an oil pump and running at full throttle will be shifting a lot more oil through the motor than the equivalent of 40:1. At full bore it is around 20:1. Bare runs 24:1 and I'm sure he's not changing plugs all the time. I know you won't be on full bore all the time, but sometimes you will.
higgsy
pre mix
Feb 19, 2012 18:20:19 GMT 1
Post by higgsy on Feb 19, 2012 18:20:19 GMT 1
Have to agree, I've never had cold start problems or plug fouling, even on Champion N80 race plugs, the LC/YPVS starts first time no matter what the weather, I'd be wanting a bit more oil in there myself than 40-1. Just my opinion of course.
No wear on the bores of the LC on 33-1 and that's at full bore a lot of the time :-)
Was thinking of going down to 25-1 for the reason Arrow pointed out, we'll do some testing and see how it burns.
pre mix
Feb 19, 2012 20:03:40 GMT 1
Post by arrow on Feb 19, 2012 20:03:40 GMT 1
The trouble with pre-mix is its only correct for a small part of the rev range. You can set it up for full bore use and not worry too much about a bit more smoke when your pottering about. Much better than going the other way and under oiling the motor at high speed. Different thing but, I have heard TZ 750's running 'R' on as rich as 12:1 (they don't spend much time pottering about)
pre mix
Feb 20, 2012 20:32:17 GMT 1
Post by shane2011 on Feb 20, 2012 20:32:17 GMT 1
thanks arrow for all the advice
pre mix
Feb 24, 2012 12:37:24 GMT 1
Post by rich on Feb 24, 2012 12:37:24 GMT 1
All I can say is that a mate of mine tried running his 31K on the road at 20:1 and it was far too much oil. The ends of the silencers were dripping with the stuff and you and the bike ended up splattered if you rode behind him. I guess the answer would be how do you ride? If you ride sensibly most of the time with the odd blat then 40:1 is probably ok (this is what I have run for years but like Martin I have found some minor scoring on my pistons) but if you ride hard then 33:1 might be better?
higgsy
pre mix
Feb 27, 2012 11:31:11 GMT 1
Post by higgsy on Feb 27, 2012 11:31:11 GMT 1
One of the downsides of premixing as pointed out is the same amount of oil is going in no matter what the throttle position, if you do a lot of town work or tend to potter around, I think 40-1 would be about right, but if you hold it open for a length of time then I'd be wanting more oil. Like you say it depends on how much you thrash it :-)
pre mix
Feb 27, 2012 13:28:34 GMT 1
Post by arrow on Feb 27, 2012 13:28:34 GMT 1
If I was running pre-mix myself I would go for 30:1 and a top of the range full synthetic oil.
pre mix
Feb 27, 2012 14:52:08 GMT 1
Post by rdstars on Feb 27, 2012 14:52:08 GMT 1
How many jet sizes do you need to go up going from pump to pre mix?
pre mix
Feb 27, 2012 15:01:43 GMT 1
Post by Norbo on Feb 27, 2012 15:01:43 GMT 1
1 size for pre mix
