Post by fatfredfaefife on Feb 12, 2012 16:49:19 GMT 1
I have a 31k and I am replacing the front wheel bearings, so bought a set from gambits. When I received them they are larger than than the ones I took out, so thinking that the wheels might be of a later model ID markings on the wheels are Y-2 & F19, which bearings do I now have to order? Outer diameter of the ones I took out are approx 36mm yambits ones 42mm.
Post by rich on Feb 12, 2012 17:03:57 GMT 1
They've sent you the wrong bearings. All YPVS front wheel bearings are the same and should be 12x37x12mm (6301). You can probably get them way cheaper at a bearing factor as they are a very commonly used size.
Post by fatfredfaefife on Feb 13, 2012 12:55:31 GMT 1
Thanks Rich.....Quick call to Yambits this morning and all sorted, top place to buy your bits!
Post by rich on Feb 13, 2012 20:44:24 GMT 1
Nice one Fred
