Post by adamp2006 on Feb 9, 2012 19:59:15 GMT 1
So my lc came with no clocks , i managed to snag rev counter off evilbay and wanna test that everything works, the rev counter itself was easy enough , but i was wondering if there was a way to test the temp gauge without having to hook it all up and have a temp sender connected ?
Post by Deleted on Feb 9, 2012 20:40:52 GMT 1
there is no way to test without it being connected to the sender unit as it is part of the circuit i can explain how to do this if you want
Post by oldelsieboy on Feb 9, 2012 21:24:32 GMT 1
So my lc came with no clocks , i managed to snag rev counter off evilbay and wanna test that everything works, the rev counter itself was easy enough , but i was wondering if there was a way to test the temp gauge without having to hook it all up and have a temp sender connected ? AFAIK if you connect the gauge to the loom, turn the ignition on & ground the lead that should connect to the temp sender the gauge should read full/high/in the red. HTH OEB
Post by davey on Feb 10, 2012 7:59:14 GMT 1
oldslsie boy is spot on , i tryed all ways to test mine and this is the only way mate , however for some reason mine is working again but doesnt red out when earthed,,,, wierd
Post by Delbert on Feb 11, 2012 20:20:46 GMT 1
oldslsie boy is spot on , i tryed all ways to test mine and this is the only way mate , however for some reason mine is working again but doesnt red out when earthed,,,, wierd strange mines the same , will just about read half way when earthed but works fine with me landy sensor
Post by Deleted on Feb 12, 2012 6:48:17 GMT 1
just ground mine out and it went about 1/4-1/3 into the green, hope its ok
Post by Deleted on Feb 13, 2012 3:09:33 GMT 1
oh well, at least theres signs of life, the loom is new, the sender unit is new, the temp guage 31 years old,i have a feeling everything will be sweet.
Post by adamp2006 on Feb 14, 2012 13:44:23 GMT 1
Thanks for the replies guys, as the loom is in bits for cleaning and rewrapping and the wires had been chooped on the gauge me and a mate i did mechanics with studied the wiring diagram and made up a makeshift mini loom for the gauge , so 2 bits of wire and a 10a fuse worked a treat if you can't just plug and test
