Post by Deleted on Jan 27, 2012 3:01:56 GMT 1
the paint im using to paint my upper and lower cases and barrells needs to be put in the oven at 95c (200F) for 1 hour to cure properly,would this sort of heat melt or damage the engine mounting rubbers? thanks
Post by arrow on Jan 27, 2012 7:43:58 GMT 1
No, they will be fine.
Post by Deleted on Jan 27, 2012 9:37:54 GMT 1
thanks arrow, finally split my cases today, gee some of the bolts were tight,clutch basket,fly wheel and the one that holds on the oil and water pump drive,had to buy a 29mm,24mm socket,at 1st im thinking what have i done, but hey sometimes you just have to jump in the deep end, its interesting to see all the damage done to screws bolts etc,the clutch shaft and gear selector shaft were bent, but the crank looks good as does all the teeth so fingers crossed it will be a fairly smooth operation, but also today my new radiator cover arrived and got mangled in transit, i havent heard back from the seller yet,this was the 1st thing i got that didnt arrive intact, oh well,
Post by Deleted on Jan 27, 2012 9:38:35 GMT 1
thanks rave,
