Post by deanord on Jan 23, 2012 1:09:42 GMT 1
I'm almost there thank god, but final checking reveals a few bits missing:
YPVS F2, 1WT btw...
choke assembly, the one i have is a larger thread than those on my spare set of carbs.. need the full shaft - anyone?
seat locks - any one got a set with keys?
clutch cable holding clip - the one near the bottom end of the cable that holds the outer in the groove on the casing?
Rear tank securing plate & rubber? - the one under the front of the seat...
on the info front... Anyone used R6 switches? particularly the RH side with the R6 throttle tube - need to shorten the cable a little - but cant find any solderless nipples of the right type to put on it - any thoughts?
cheers in advance...
JD
Post by Norbo on Jan 23, 2012 13:59:24 GMT 1
Post by deanord on Jan 24, 2012 20:23:05 GMT 1
Cheers Norbo, can you measure the thread diameter on the choke plunger please? (vernier at 90' to the thread will suffice) - seen the other stuff too - so brace yourself for an email when you have confirmed the thread info... thanks again! JD
Post by deanord on Jan 25, 2012 14:50:40 GMT 1
Norbo - just checked and they are 4CE carbs - i also have 1UA carbs - think i'll be cleaning them up - better idea?
Post by Norbo on Jan 26, 2012 15:16:42 GMT 1
Yes the ones i have wont fit the 4CE ones only the 31K F2 and LC carbs ,
Post by deanord on Jan 27, 2012 0:27:39 GMT 1
cheers, i've cleaned up the 1UA's and put them on - not great but it should get me going... pity really as the 4CE ones are mint!
Post by midlifecrisisrd on Jan 27, 2012 9:33:29 GMT 1
cheers, i've cleaned up the 1UA's and put them on - not great but it should get me going... pity really as the 4CE ones are mint! Why not try Yam dealer and see if still available and fit a remote choke. Choke fitting at carb - 1YH-1410A-00 ( not sure if 0 before A is an O ) Cable and knob - 4CD-F6330-00 Steve
Post by deanord on Jan 27, 2012 20:50:42 GMT 1
damn fine idea - thanks!
Post by deanord on Jan 27, 2012 21:04:29 GMT 1
dont have a right hand side lock - sadly thats the prob.. got the other side! anyone got one laying about?
