Post by gerumgoin on Jan 7, 2012 18:58:02 GMT 1
k guys,on the swith gears on the 125lc which ones can you use,ive seen the old rd125 and the tzr125 right hand look the same,but can these be used on the 125lc,is there just wires that need doctoring? ? and same for left side??
Post by mellow on Jan 7, 2012 19:08:30 GMT 1
im pretty sure its just one of the connectors is different m8 so no big issue that cant be sorted.norbo will know
davslc
Post by davslc on Jan 7, 2012 19:13:15 GMT 1
my left hand one is not off a mk1 as there is a yellow/red wire that is not used(checked wiring diagram it doesn't exist) ,all other colours are correct ,i have checked and the yellow/red wire goes to the indicator switch so think its off a later model with self cancelling indicators .
also on the later version right hand you have a pass switch but not on earlier models ,they all work the same just may have to trace wires and alter connections to suit .
Post by gerumgoin on Jan 19, 2012 8:09:07 GMT 1
So if i got a right hand switch gear off a YAMAHA TZR125 2RK ,what would be the difference,if the wires or different could i use the top part with the switches on?
stevew
Post by stevew on Jan 22, 2012 11:19:29 GMT 1
So if i got a right hand switch gear off a YAMAHA TZR125 2RK ,what would be the difference,if the wires or different could i use the top part with the switches on? ive got 2 off a mk2 lc in good nick
