Post by seezyer on Jan 6, 2012 9:22:16 GMT 1
help please guys! can anyone post a pic of how they have mounted the powervalve servo motor in an LC frame, is there and drawings of a bracket out there that i can attach to the frame? i can sit and make one but was wondering if anyone can post a photo of how they have located the servo motor when putting a powervalve engine in an LC...
thanks in advance guys :-)
higgsy
Post by higgsy on Jan 6, 2012 11:11:43 GMT 1
I put mine in the triangle beneath the coil, just P-Clipped in place. I've seen them cable - tied on as well. A nice alloy bracket would be a far more astetically pleasing solution!
paulo
Post by paulo on Jan 7, 2012 21:59:19 GMT 1
Hi mate, just made up x2 simple brackets for mine and used the coil cover mounts. Hope this helps or gives you a starting point for your own mounting bracket. Paul.
Post by seezyer on Jan 9, 2012 9:04:43 GMT 1
aaah, thanks loads guys! i have been offering it up to the frame UPSIDE DOWN!! hahaha, i was being a bit thick there, it looks like it will fit MUCH better the other way up!!. mines from a TZR and looks like the powervalve cables are waaaaay longer than a ypvs...
Post by steveloomis on Jan 12, 2012 18:05:10 GMT 1
Easiest mount I've seen so far. I have one to mount one my 4L0/RZ engined bike
Post by bare on Jan 12, 2012 19:08:00 GMT 1
Clean install. How are the Cable runs? IF you used longer OEM style screws, could you not fit the plastic headstock cover back on?
paulo
Post by paulo on Jan 12, 2012 21:26:54 GMT 1
Hi bare, cable runs are nice and flowing with no sharp bents etc. Standard YPVS cables fitted, but close to maximum available adjustment used !. Used a LC2 cutch cable on my build which is at maximum adjustment too. Been looking on the Venhil cables site, so next job is shortening the inner cables slightly, but going to leave it till the end of summer, just want to ride the thing - done 150 miles on Sunday, - had some 996 rider thinking he could pass me on a fast twisting road - he pulled up behind me at the lights 10 miles down the road, flipped his lid up and smiled and gave the thumbs up !. Would fit one if i had one, but not paying the prices that people want for them, will get one some time down the road. If you want photos of the cable run, just let me know. Paul.
