Post by atomicstroker on Dec 27, 2011 0:11:11 GMT 1
Post by atomicstroker on Dec 27, 2011 19:47:56 GMT 1
Thanks mate I was terrified of burning out the whole loom or worse.
Post by Bazille on Dec 27, 2011 20:31:30 GMT 1
Hi As always when welding : DISCONNECT YOUR CDI,- you could cause a surge and blow it, just make sure to unplug all connectors to it!!
cheers
Post by twostroker on Dec 30, 2011 22:24:54 GMT 1
Hi As always when welding : DISCONNECT YOUR CDI,- you could cause a surge and blow it, just make sure to unplug all connectors to it!! cheers good advice, when i worked in a baody shop my old boss burnt out a few car e.c.u's by welding up sills and arches,we even had a newish alfa romeo that suffered e.c.u damage and wouldnt run again just from being baked at 60 degree's c
Post by Norbo on Jan 1, 2012 11:30:13 GMT 1
as above you will be fine ive done lots of little jobs like this on cars and bikes . Just disconect the CDI and battery and you will be fine. but ofcourse get any wiring as far away as you can from the point of weld becourse it gets bloody hot. However you can spot weld on spots so it wont get to hot with a constent weld thats a good trick i have used in the past .
