davslc
Post by davslc on Dec 26, 2011 18:59:19 GMT 1
bought a used rear shock today off a 350lc its mint but spring is slightly scratched could do with coating is there any way to split the rear shock to remove spring.
cheers dav
Post by billy on Dec 26, 2011 20:49:36 GMT 1
Are you going to use the shock for a 125? If so, I want to let you know that 350 LC shocks are a bt shorter then 125 shocks and I think it's a tad too wide for the swingarm mount aswell.
I've taken a 350 shock apart and it was easy peasy compared to the 125 shocks I've tried it on. I didn't have to use a spring compressor at all, I just turned the spring adjuster to the sloppiest setting and then I could fiddle the retainer circlips out with very little effort, almost by hand if memory serves me right. I don't know if my 350 shock spring was in tip top condition or not though.
Post by lcowner on Dec 26, 2011 23:15:24 GMT 1
you'll need to compress the spring to remove the two "c" type half washers at the top of the spring, i took mine to my local motorcycle shop he compressed it for me charged £1.50 i recall +1
davslc
Post by davslc on Dec 26, 2011 23:27:27 GMT 1
cheers guys
davslc
Post by davslc on Dec 27, 2011 15:52:26 GMT 1
sorted now done and fitted cheers
Post by billy on Dec 27, 2011 16:24:03 GMT 1
Nice, but you gotta install the inner muddy first!
davslc
Post by davslc on Dec 27, 2011 16:34:49 GMT 1
its only on temp as i have to do swingarm yet ,most of the bits fitted will be coming back off just doing a mock up of bits i restore as i go along
Post by billy on Dec 28, 2011 0:05:42 GMT 1
its only on temp as i have to do swingarm yet ,most of the bits fitted will be coming back off just doing a mock up of bits i restore as i go along Oh I see, I kind of suspected that but thought I'd say it anyway just in case. I realise now though, considering the neat standard of your build so far, it was damn foolish of me thinking you'd put that rusty ol swinger on permanently with no fresh powdercoat on it.
davslc
Post by davslc on Dec 28, 2011 6:40:13 GMT 1
cheers fella ,was considering something different with the swingarm but we will see
