drzsimon
Back after a long break
Post by drzsimon on Dec 23, 2011 22:17:11 GMT 1
Greetings, Has anyone know where I can find a table or list of all the bolts & nuts (size/pitch/length) for the 350N1, chassis and engine? I fancy doing the bike in the stainless shouldered hex bolts that ProBolt do, but as it was already stripped I haven't got all the bolt sizes. I seem to remember having one for the LC but I can't find it or the site in my browsing history. (Found some other good stuff I'd forgot about though... ) Like these: www.pro-bolt.com/stainless-steel/stainless-steel-bolts-flanged-hex.htmlNeed a good reason to get in the garage once the extended family turn up over Xmas Thanks in advance, Merry Christmas! Simon
Post by oldelsieboy on Dec 23, 2011 22:28:00 GMT 1
Greetings, Has anyone know where I can find a table or list of all the bolts & nuts (size/pitch/length) for the 350N1, chassis and engine? Simon If you have a parts fiche for the N1 check out the part numbers for the bolts you require. The number should look similar to this, 90208-06045. The last 5 numbers tell you the thread dia & length, M6 x 45mm. HTH OEB
Post by oldelsieboy on Dec 24, 2011 9:39:21 GMT 1
If you have a parts fiche for the N1 check out the part numbers for the bolts you require. The number should look similar to this, 90208-06045. The last 5 numbers tell you the thread dia & length, M6 x 45mm.HTH OEB Interesting stuff Mr. OEB ;D
Post by mellow on Dec 24, 2011 10:28:35 GMT 1
i learnt this info when doing mine just be aware there is the odd occasion when the length is just so wrong sometimes it says 60 or 70 which really is just too long
