Post by seezyer on Dec 21, 2011 15:40:31 GMT 1
does anyone know if there is a 520 rear sprocket available for an RD250lc wheel (or anyone who makes specials) as the TZR engine has a 520 front sprocket and the RD wheel is 530 (thanks OEB) :-) ....(TZR engined RD Project). or does anyone know if the 530 front sprocket from the RD will fit the TZR outpus shaft.......
cheers :-)
Post by oldelsieboy on Dec 21, 2011 16:08:13 GMT 1
does anyone know if there is a 520 rear sprocket available for an RD250lc wheel (or anyone who makes specials) as the TZR engine has a 520 front sprocket and the RD wheel is 525....(TZR engined RD Project). or does anyone know if the 525 front sprocket from the RD will fit the TZR outpus shaft....... cheers :-) RDLC rear sprockets are 530 as standard. AFAIK you cannot buy a 520 rear sprocket off the shelf but it is possible to have them made, try B & C EXPRESS Make sure you order a 250 sprocket as the 350 is a different fitting/bolt pattern. HTH OEB
Post by seezyer on Dec 21, 2011 17:20:56 GMT 1
cheers for the help. will try to fit the 250lc sprocket to the TZR engine and see if it goes, if not il give your chaps a shout. cheers :-)
Post by ozzy on Dec 22, 2011 12:55:35 GMT 1
i have had this conversation with norbz, as my lc 250 race bike as a 350lc wheel complete in, norbz has the sprockets for the 350 wheel and front ,or like said bc will machine i think the rear is 38.00 front 17.00, if you can get rear wheel set up norbz does 7.00 and 20.00 for the rear. he does 520 chains too i think send him a pm..
Post by Norbo on Dec 22, 2011 14:08:31 GMT 1
There is a standard replacement for a 350 on 520 but nothing for a 250 . However you can mashen a 250 one down i did this for my race bike
higgsy
Post by higgsy on Dec 22, 2011 19:49:59 GMT 1
The LC front sprocket won't fit on the TZR engine, the splines are different.
Only option other than using a 350 wheel is to machine a 350 sprocket to fit the 250 wheel as previously mentioned.
You might be able to get a 525 front sprocket for B&C or Talon as a one off, but as far as I know nothing fits as standard with a 525
Post by seezyer on Jan 3, 2012 16:10:26 GMT 1
dam! thanks guys, i will ring around a bit and see, but i think il be looking out for a 350 rear wheel then... :-(
Post by Bazille on Jan 3, 2012 16:28:20 GMT 1
Hi I have a 350lc rear wheel if you still need one! have the brake plate only bits missing are the 3 cush drive rubbers (1 present) cheers Colin
