Post by marsbar350 on Dec 20, 2011 19:02:31 GMT 1
hi guys have had the problem where the stand sits too far forward not allowing the back wheel ground clearance heres a couple of pics top of the stand is a bit saggy acqiured some 1.8mm plate from work and made these what do you reckon to the mounting holes on the frame? will tack the plates on at work tomorrow.try fitting and report back ;D
Post by arrow on Dec 20, 2011 20:29:58 GMT 1
Holes on frame look surprisingly good.
Post by Norbo on Dec 21, 2011 13:24:57 GMT 1
They dont look ovel are anything mate quight round.
Post by marsbar350 on Dec 21, 2011 16:08:57 GMT 1
well ive welded the tags on top today "during my lunch break"pleased with the results.just got home and fitted.everything spot on.stand sits nicely and backwheel 15mm off the ground.just what i was after.took off agin and sprayed it plastikote satin hopefully fit tomorrow.will post some pics later
Post by marsbar350 on Dec 21, 2011 20:20:46 GMT 1
all sprayed up ready for fitting tomorrow ;D now have to spray the exhausts again :-/some petrol damage from a badfly placeed overflow pipe
Post by marsbar350 on Dec 25, 2011 21:27:48 GMT 1
