Post by ianboom on Dec 19, 2011 20:11:40 GMT 1
Hi
I've just fitted a PCDI-10V to my hybrid-it starts and runs fine, and when I plug the programmer in, it comes up with the engine speed and power valve angle, but after a few seconds, the display clears and just the engine seped is displayed-when this happens the displays becomes virtually unreadable.
Any ideas or has anyone come accross this before?
Cheers, Ian.
paulo
Post by paulo on Dec 19, 2011 22:22:48 GMT 1
Got the same set up on my bike, have only had the programmer on a couple of times for a bit play, and it worked fine, was able to access all the menu's etc - left it on for quite a while, while reading through the instructions and fiddling. I would say it shouldn't be happening, try emailing Zeel direct, they pointed me in the right direction when i had some minor fitting questions.
Post by Bazille on Dec 19, 2011 22:53:22 GMT 1
Hi guys, where did you but the zeel units from as i need to get one for my 500lc??? (UK preferabaly) are they easy to fit? i have a 350 powervalve control unit on at the moment which isnt ideal as the power valve cuts in at different RPM!
cheers colin
Post by ianboom on Dec 20, 2011 17:38:28 GMT 1
Emailed Borut and he was spot on-I needed resisitor plugs!
I had resistor caps and thought resistor caps and plugs would give a smaller spark so ran non res plugs.
Fitted some BR9ES plugs and it works fine!
Ian.
Post by ianboom on Dec 20, 2011 17:41:35 GMT 1
Hi guys, where did you but the zeel units from as i need to get one for my 500lc??? (UK preferabaly) are they easy to fit? i have a 350 powervalve control unit on at the moment which isnt ideal as the power valve cuts in at different RPM! cheers colin You can buy units from Norbo off this site, or direct from Borut himself. You can mod your powervalve controller to start opening and fully open at different speeds-have a read of this tzr250.com/forums/index.php?topic=753.30Regards, Ian.
