Post by ivymike on Dec 14, 2011 20:29:06 GMT 1
hi all .going to be doing some more work to my rd/rgv350. is it possible to fit the carbs using standard air box?anyone done this? if so what do I have to do.
Post by midlifecrisisrd on Dec 14, 2011 20:42:58 GMT 1
Lc or ypvs?
Using them on my ypvs, pwk's 5mm shorter so reed spacers a good idea, I used 10mm as it allows the LH one to clear the clutch arm. I also slotted the airbox mounts so when the oil tank was removed it allowed the airbox to move back to ease fitting.
Lc should be about the same but no problem with clutch arm, just fit the airbox rubbers to the carbs before fitting as they are a bit of a stretch.
Post by oldelsieboy on Dec 14, 2011 21:13:00 GMT 1
Lc should be about the same but no problem with clutch arm, just fit the airbox rubbers to the carbs before fitting as they are a bit of a stretch. Better still use the KR1S carb to airbox rubbers OEB
