Post by loctite on Dec 11, 2011 22:10:21 GMT 1
hi guys will not be long before i start my hybrid 4l1 with rgv front and rear my question is the rear brake light how do we connect one up i will(may) be using standard hangers and rear brake lever im guessing i need some kind of pressure switch on caliper any ideas or links to parts.cheers nigel
Post by oldelsieboy on Dec 11, 2011 22:21:55 GMT 1
hi guys will not be long before i start my hybrid 4l1 with rgv front and rear my question is the rear brake light how do we connect one up i will(may) be using standard hangers and rear brake lever im guessing i need some kind of pressure switch on caliper any ideas or links to parts.cheers nigel This is how I mounted my master cylinder & attached to the brake lever. I just attched the brake switch to the original point on the lever. HTH OEB
Post by loctite on Dec 11, 2011 23:00:03 GMT 1
thanks oeb for pics info i see youve a metmachex swinger how does this compare to the banana swinger width wise is there enough clearance cheers nigel
Post by oldelsieboy on Dec 11, 2011 23:18:45 GMT 1
thanks oeb for pics info i see youve a metmachex swinger how does this compare to the banana swinger width wise is there enough clearance cheers nigel It was a JMC arm & it was very tight for the wider wheel as it was manufactured for a standard LC wheel. Had to machine the caliper hanger & sprocket carrier to suit. OEB
Post by loctite on Dec 11, 2011 23:29:59 GMT 1
thanks for clearing that up well if i struggle reguarding brake light switch i can always set up a brake light pressure switch on rear caliper i presume cheers nigel
