Post by arrow on Dec 2, 2011 23:37:32 GMT 1
Hi, how do people on here go about draining the gearbox oil on the 350 Lc (4LO) ? The drain bolt is very difficult to reach with a spanner or a socket due to the R/H exhaust. I have done it but is there an easier way ? Thanks, Arrow.
Post by billy on Dec 3, 2011 11:52:40 GMT 1
Hmm, I have no problems reaching the drain bolt at all. Sure, it's a tiny bit tight there but nowhere near "impossible" imo. Just use an extender and you'll be fine.
Post by lcowner on Dec 3, 2011 11:55:08 GMT 1
there is always a bit of play between he pipes where u can splay apart and get a socket in
Post by oldelsieboy on Dec 3, 2011 12:05:19 GMT 1
there is always a bit of play between he pipes Shouldnt be if they are standard pipes OEB
Post by lcowner on Dec 3, 2011 12:31:32 GMT 1
ur right nigel im talking aftermarket ones with springs collars ect
Post by rich on Dec 3, 2011 14:12:33 GMT 1
You should be able to get a socket and extension in there. If you can't, surely whipping the r/h pipe is no biggie? If you have sprung headers it's only one bolt
Post by arrow on Dec 3, 2011 17:22:16 GMT 1
Thanks Guys.
Post by arrow on Dec 19, 2011 0:30:33 GMT 1
Totally sorted. Got this off 'the bay' I am using a non standard drain plug from Halfords (13mm A/F), but these are available in most common sizes. puts the extension bar well away from the R/H exhaust. I like to do regular gearbox oil changes (what ever oil I am using) as it's only 1.5 litres and un-filtered, cheap job and good for the motor. Well worth doing IMO. Attachments:
Post by Norbo on Dec 19, 2011 13:27:58 GMT 1
I agree most people dont bother replacing the oil or plugs from one year to the next . i replace the plugs every year and depending on what miles i do the oil as well .
Post by Paul Dawkins on Dec 19, 2011 18:14:26 GMT 1
I change oil, plugs, brake fluids and clean the air filter every year on all my bikes.
brake fluid is so easy to do and its so cheap to buy but makes such a difference.
