Post by daglad on Nov 30, 2011 21:23:31 GMT 1
I am thinking of getting a zinc plating kit to play with. Anybody any experience with one. I am looking at a kit from Gateros Plating. Any advice would be appreciated before i commit to buying one
Post by midlifecrisisrd on Dec 1, 2011 9:36:45 GMT 1
Not got the zinc one but did get the nickel one from them.
Simple to use and good results. Most important thing is getting the stuff absolutely clean first.
Post by nikfubar on Dec 1, 2011 11:32:28 GMT 1
I've only done nickle plating, but once you know what your doing & follow the instructions exactly you get good results. Heres a set of old head bolts I plated a few weeks ago, just sold them on ebay for £20.00 ;D
Post by daglad on Dec 1, 2011 13:21:39 GMT 1
Cheers guys, when i said zinc i meant nickle. Your Head bolts look splendid nik, i think i will take punt and have a go, i have quite a few bits to do on my fireblade as well. i will post the results, probably have a bash over the xmas break.
Post by nikfubar on Dec 1, 2011 13:44:03 GMT 1
Nice one ;D All your steel parts need to be spotless, I use a cup brush on an electric drill, then you need to dip them in acid for about 20 mins, I use Jewsons brick & morter cleaner. Then rinse in distilled water, I get this from local motor factors in 5ltr tubs, then in the plating bath for about 20-30 mins. You need an old car battery to power it & you have a resistor coil with the kit to regulate the voltage, you want around 4v measured from the negative wire to the nickle anode suspended in the bath. If the voltage is too high it will burn out the plating solution & blacken the piece you are trying to plate & if the voltage is too low it will take ages & you get a bumpy matt finish. Wear rubber gloves or the oil on your fingers will get on the steel & ruin the finish. Any thing you need to know just ask ;D Here's a kick start I modyfied & plated & various other bits
Post by shandyboy on Dec 1, 2011 16:47:34 GMT 1
Nick what kit you using mate and whats the cost cheers alan
Post by nikfubar on Dec 1, 2011 17:08:51 GMT 1
Post by daglad on Dec 1, 2011 18:24:00 GMT 1
Cracking advice nik, thank you very much, i was looking at the £125 kit from gateros do i need this one or will the £85 be ok. The bits you have done look first class. I've noticed the water pipe i didn't realise you can plate alloy?
Post by nikfubar on Dec 2, 2011 9:35:59 GMT 1
Cracking advice nik, thank you very much, i was looking at the £125 kit from gateros do i need this one or will the £85 be ok. The bits you have done look first class. I've noticed the water pipe i didn't realise you can plate alloy? Which kit is it can't see it Yeah you can do ali as well but you need to use this on the ali first www.gaterosplating.co.uk/Zincate.phpNasty stuff when you are mixing the chemicals up do it outside.
Post by daglad on Dec 4, 2011 12:50:20 GMT 1
I don't know how to add a link but it is on the Gateros website and the kit is titled as
THE ULTIMATE SUPER BRIGHT ZINC/NICKEL PLATING KIT
It looks like it has everything i need in one hit.
Post by nikfubar on Dec 4, 2011 21:12:52 GMT 1
Still can't find it the only ultimate kit I can see is a brush plating one. To add a link open the page you want to link then go to the header right at the top of the screen, right click on it & a drop down box appears, left click on COPY, return to your post, right click & drop down box apperars, left click on PASTE. Job done
Post by LC_BOTT on Dec 5, 2011 10:46:42 GMT 1
Nick, why did you chose to go with the nickel rather than the zinc plating, was it for a better sinier finish, or is there a durability issue with zinc, as i believe it's a sacrificial coating??
Post by nikfubar on Dec 5, 2011 11:28:21 GMT 1
I went with bright nickel as it's a nice shiney finish, there are lots of nuts, bolts & parts which are not easy to replace with stainless & I can't be arsed to paint so this is a quick easy solution that looks good ;D
