Post by davey on Nov 26, 2011 20:19:04 GMT 1
hi guys , im just doing a top end rebuild on my 250 lc and all is good apart from i have been sent the wrong little ends, the ones that came out would it be wise to reuse them , everything else is new pistons gudgen pins etc. the ones that came out look perfect , what you all think as i dont want to have to wait a week till i get the new ones as the wifes going ape as its in the kitchen on hold. let me know ur thoughts . cheers Dave
Post by nikfubar on Nov 26, 2011 20:29:38 GMT 1
IMHO I would fit new ones also I would get some OEM circlips & bin the others if they are not genuine, new Yamaha ones.
Post by midlifecrisisrd on Nov 26, 2011 20:34:15 GMT 1
Order new ones for what they cost.
Try calling norbo, if he has them in stock he can post them straight out.
Post by oldelsieboy on Nov 26, 2011 20:38:16 GMT 1
hi guys , im just doing a top end rebuild on my 250 lc and all is good apart from i have been sent the wrong little ends, cheers Dave Can I ask, why are they wrong? OEB
Post by cb250g5 on Nov 26, 2011 21:07:39 GMT 1
Used PJME by any chance?
Post by davey on Nov 28, 2011 14:26:28 GMT 1
the external mesurment is to small altough the fit round the pin is good. i reckon about 1 mm slop in the rod,,, mmmmmmmmmmmm not good , i guess if doing this for the first time it might have gone unoticed by somone, just shows that double checking all parts even when coming from a good source need to be double checked although on start up it would have been very apparent albeit i wouldnt think for very long .
Post by cb250g5 on Nov 28, 2011 20:30:46 GMT 1
the external mesurment is to small altough the fit round the pin is good. i reckon about 1 mm slop in the rod,,, mmmmmmmmmmmm not good , i guess if doing this for the first time it might have gone unoticed by somone, just shows that double checking all parts even when coming from a good source need to be double checked although on start up it would have been very apparent albeit i wouldnt think for very long . PJME supplied me (by mistake) with exactly the same wrong little ends a while back. The ID is correct but the OD is 1mm undersize. I can't remember what they are the correct bearing for...but not Yamaha.
