Post by zxr59 on Nov 25, 2011 18:07:52 GMT 1
I have a German 4lo frame and wondered if you guys would remove or leave the steering lock on the side of the headstock,i was going to remove it but just wondered what the general concensus is. also whats the best method for removal and to fill the hole afterwards Thanks in advance
Post by soccersmyth on Nov 25, 2011 19:20:01 GMT 1
If it has the lock cover, i'd leave it. You can alway sorce up a lock and key sometime.
If you want to hide the fact it a german, get busy with the grinder to take it off and then the welder to close the hole.
Don't see any other way you could do it
Post by billyboy on Nov 25, 2011 19:44:00 GMT 1
i have removed mine and welded a small blanking plate over the top. atb
Post by onewheelsenough on Nov 25, 2011 19:44:07 GMT 1
Post by Paul Dawkins on Nov 26, 2011 15:14:14 GMT 1
I did the same as that, welded a bit on and got a UK ignition switch.
