Post by daglad on Nov 24, 2011 22:38:43 GMT 1
Is it possble to polish out, or some other method of removing light scratches from the plastic engine case (Sprocket side)
Or am i being dumb as usual?
Post by midlifecrisisrd on Nov 25, 2011 9:39:15 GMT 1
Hi,
Can be polished just like alloy. Have used autosol or brasso in the past.
If it's deep you can use some fine wet and dry first.
Be careful if using power tools as too much heat build up can damage it.
Post by daglad on Nov 25, 2011 13:33:08 GMT 1
Cheers steve, i thought i had read somewhere you can do them but wasn't sure. Would you use a light buffing mob on a bench grinder converted to a polisher or would that be too severe?
Post by Shytalk on Nov 25, 2011 15:54:53 GMT 1
Bench grinder is too fast, if you can get a variable speed drill that will do the job
Post by midlifecrisisrd on Nov 25, 2011 17:08:23 GMT 1
Bench grinder is too fast, if you can get a variable speed drill that will do the job +1 Steve
Post by billyboy on Nov 25, 2011 17:21:21 GMT 1
have sprayed mine in the past with plasticote gloss black, came up like new, will need to be done in the warm this time of year tho.
