Post by daglad on Nov 24, 2011 22:30:35 GMT 1
Anybody got an alternative way of holding the cluch basket so i can tighten the darn thing without shelling out £20 for a tool which will sit on the bench forever unused and and unloved, bit like carlos Tevez really. Points will be awarded on imagination, cuning and style oh ye and cheapness ;D
Post by Deleted on Nov 24, 2011 22:40:33 GMT 1
ive seen a picture of one in the haynes manuel that is home made out of a thin strip of metal,page 44, shaped a bit like the letter S
Post by nikfubar on Nov 24, 2011 23:52:45 GMT 1
If you got an old set of clutch plates bolt a friction & plane plate together, this will lock the clutch then jam a 2p piece between the primary gears. Job done ;D Buy the proper tool, you'll be surprised how many times you use it
Post by Tone on Nov 25, 2011 7:09:19 GMT 1
I've just got a local engineering shop to weld a rod to an old plain plate. Haven't tried it yet so hopefully it wll be strong enough.
Post by trev1340 on Nov 25, 2011 15:47:54 GMT 1
I did the one out of the haynes book and it works just looks like an S if you have a bit of metal that is would put a pic up but its buried inthe back of the garage
Post by nikfubar on Nov 25, 2011 19:12:38 GMT 1
Post by daglad on Nov 25, 2011 22:37:07 GMT 1
Cheers guys, i am going to order the one from yambits, i was having a tight arse moment £15 ain't going to kill me is it
Post by lcowner on Nov 26, 2011 0:09:52 GMT 1
Cheers guys, i am going to order the one from yambits, i was having a tight arse moment £15 ain't going to kill me is it yeah u tight git! ;D ;D
Post by Deleted on Nov 26, 2011 0:15:29 GMT 1
norbo has them , the same as that one from yambits
Post by LC_BOTT on Nov 27, 2011 10:51:54 GMT 1
But it, use it and then sell on fleabay, as very rare, mint, original, 'never seen one for sale before' and you should be £££'s in
