Post by daglad on Nov 24, 2011 21:11:05 GMT 1
I am about to start polishing my foot peg hangers. I am going to flat the casting marks first but do i need to flat the front faces as well to cut through any factory lacquer (I am guessing there is some).
paulo
Post by paulo on Nov 24, 2011 21:41:44 GMT 1
Mine weren't too bad, used varies grades of wet & dry on the heavy marks then popped them in the blasting cabinet, then a 1/2 hour each on the bench polisher. You will have to remove any lacquer prior to polishing, a fine file should be fine on the flat surfaces, but use some wet & dry / wire wool also after wards to give you a better finish, then start the polishing process - best of luck - its well worth it after all that hard work.
Post by daglad on Nov 28, 2011 23:04:01 GMT 1
I have gone through the can't wait to get started stage to the this is very theraputic stage, to the hum, this isn't quite as much fun as i thought it was stage and i am very firmley in the WHY IN THE NAME OF ALL THINGS HOLY DID I START THIS SODDING JOB!!!! Stage
Post by mellow on Nov 28, 2011 23:16:43 GMT 1
everyone gets to that stage......but once its done its so worth the pain and effort
