iainw
Post by iainw on Nov 20, 2011 22:34:43 GMT 1
You know that long push rod that goes from the LHS of the gearbox to the clutch, well, if you pull it all the way out from the sprocket side does that little ball bearing drop into the gearbox or does it stay put for when you put the rod back in?
Post by gazilla on Nov 20, 2011 22:52:05 GMT 1
It should stay put but will fall out if you move the bike about a bit.But will only fall out the left casing not into gearbox.
iainw
Post by iainw on Nov 20, 2011 23:46:31 GMT 1
Thanks, I'll stop worrying now.
