Post by loctite on Nov 20, 2011 18:37:24 GMT 1
hi guys im just starting a 250lc project anyway before p/coating im mocking bike up,the main stand when fitted is not lifting rear wheel clear of ground ive tryed two main stands same prob with both,the frame looks to be ok where brackets are located.any advise please nigel
Post by winnerevo1 on Nov 20, 2011 20:24:39 GMT 1
Common problem mate, it's due to a bit of movement in the frame and wear on the frame stops.
Easiest solution is to weld a couple of discs (spacer) on top of the stand, probably only need to be 1-2mm thick so it takes up the slack.
I have a stand with this mod but not got any pics at the mo but I should take some for reference purposes.
j10src
Post by j10src on Nov 29, 2011 21:05:50 GMT 1
Ive just fitted a centre stand to my 250lc and it had a similar mod in the way of 2-3mm of weld on the top of the upper stand legs and it's spot on height wise now :-)
Post by loctite on Nov 29, 2011 21:52:53 GMT 1
thanks guys frame rail is twisted and ripped new tube required out with engine then doh
